Crysis 3
Publisher: EA
Mixing the open-world combat of Crysis with the more tightly scripted urban jungle of Crysis 2, Crysis 3 is a smorgasbord of visual effects and polygons galore. With DirectX 11 support, high resolution textures and incredibly detailed characters models, it's laid down the gauntlet for the next generation of consoles and games alike when it comes to gorgeous graphics
We test using the Very High detail preset and with Very High texture resolution. lens flare and motion blur are both enabled, although due to its heavy performance impact, anti-aliasing is disabled.
As explained earlier, we use a custom macro-driven 60 seconds play-through from the single player mission Red Star Rising. The 60 seconds of gameplay takes place in a large open environment heavy on water and particle effects. Each test is repeated three times, with the average result taken.
Nvidia GeForce GTX 690 4GB
AMD Radeon HD 7990 6GB
Nvidia GeForce GTX Titan 6GB
AMD Radeon R9 290X 4GB (Uber Mode)
Nvidia GeForce GTX 780 3GB
AMD Radeon R9 290X 4GB (Quiet Mode)
Nvidia GeForce GTX 770 2GB
Nvidia GeForce GTX 680 2GB
Nvidia GeForce GTX 670 2GB
AMD Radeon R9 280X 3GB
AMD Radeon HD 7970 3GB GHz Edition
Nvidia GeForce GTX 760 2GB
Nvidia GeForce GTX 660 Ti 2GB
AMD Radeon HD 7950 3GB with Boost
AMD Radeon R9 270X 2GB
Nvidia GeForce GTX 660 2GB
AMD Radeon HD 7870 2GB
20
30
40
50
60
70
80
90
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
